solenoid vavles
oldschoolcivic
04-27-2004, 09:15 PM
Ok i have a 90 civic lx and putting in jdm b16. I see the jdm is suposed to have purge cutoff solenoid valve and a pressure regulator cut off solenoid valve. My car has the purge cut off solenoid valve. So my question is what am i suposed to do with the wiring, or do i need that pressure cut-off valve.
shaddr3
04-27-2004, 09:20 PM
are you going to be using your AC unit?
oldschoolcivic
04-28-2004, 03:19 AM
YEs I am.
91civicDXdude
04-28-2004, 06:52 AM
just run your fuel pressure regulator directly off a vacuum port on the intake manifold. it wont make a bit of difference.
oldschoolcivic
04-28-2004, 02:35 PM
This does not help my problem. I am asking about the wiring. If i can substitute the purge for the pressure solenoid valve.
shaddr3
04-28-2004, 02:53 PM
YEs I am.
Damn because I wanted it!
