How does a boost controller work?
SlowerCivic
04-27-2004, 02:26 PM
I have a turbo xs boost controller the manual kind,exactly how do they work?
scottsee
04-27-2004, 03:47 PM
they controle the amount of air pressure going into your tb.
JoeWagon
04-27-2004, 05:05 PM
I'm SO GLAD you asked that question! scottsee that's an extremely vague answer, you just said "a manual boost controller controls boost to the engine"
http://racingknowledge.org/topic.asp?TOPIC_ID=117
Good luck reading!
scottsee
04-27-2004, 06:36 PM
im good at being vague =)
96spyderman
04-27-2004, 09:22 PM
To accurately answer the Q... A boost controller controls the amount of pressure that there is from the turbo all the way up to the intake manifold... Your/all turbos have a wastegate(internal,external) that is opened and closed depending on the amount of the pressure that is built up...a boost contr. changes when/how much the wastegate is opened/closed. If you are going to put one in, anyone with knowledge of this will tell you to install a numbered boost guage so you don't end up OVER boosting and getting little demons in your engine. Hope this helps.
