Scratching noise!
mellowboy
01-13-2002, 07:58 PM
Hey sup...i'm hearing scratching noise from my timing belt..i don't if its rubbing on the cover or if the belt is bad? Can someone please help? Thank you.
90CRXZCSi
01-13-2002, 11:01 PM
I would take off the timing belt cover and see if it is either wearing out or if it's hitting. If the belt is fine then i personally would just leave the cover to the timing belt off and see if it still hits.:confused:
mellowboy
01-16-2002, 02:19 AM
I just took off the cover and it still makin noise! I'm not sure whats going on? Its really annoying! Someone please help?
BigBank420
01-16-2002, 11:34 AM
I would definetely take the cover off and check it out. You could even have a water pump bearing going out which is really not a good thing. Also look for wear on the belt and wear on the belt tensioner. Hope this helps.
mellowboy
01-16-2002, 01:15 PM
Well i took the cover off.. and the belt is fine. I'll have to check the water pump then?
mellowboy
01-20-2002, 07:22 PM
I think i figured out what it was. Well it seems like my timing belt is really loose and so i think thats whats causing the "scratching noise?" So how do i tightened the belt..what tools do i need?
