AIR DRIED BEEF DOG FOOD
Help!
bx10466
04-26-2004, 02:27 PM
What else could be causing vibration under the hood other than the rear mount?
AccordCodger
04-26-2004, 03:26 PM
Mice?
bx10466
04-29-2004, 10:25 PM
thanks for your wisdom
AccordCodger
04-30-2004, 11:14 AM
OK, LOL done.
First, I might suggest you give your post a more meaningful title - had you done so you probably would've gotten some responses.
I believe the answer to your question is "maybe, but probably not"
Exactly when does it vibrate? The check for a (notorious) bad motor mount (which, by the way, is called the "LEFT" mount - there is no "rear" mount - that's the transmission mount. The motor mounts are left and front, with a stablizer dog bone on the right of the motor) is to put it in D while idling and switch on the A/C. If your teeth start to chatter, you've got a bad left motor mount.
92lx
04-30-2004, 12:07 PM
is it a vibration of the car, or a sound under the hood?
- Nathan
integrasedan
04-30-2004, 09:36 PM
if it's the whole car shake, check for loose exhaust pipe shaking.
if the engine shake, check motor mounts.
if it's rough idle, do a tuneup and fuel injector cleaner.
and if it's mice, call an exterminator...
bx10466
05-01-2004, 12:01 PM
I know I don't need an exterminator., at least I hope never know in NY. My 92 accord vibrates only in front. I tried the turning on the AC and yes my teeth chattered. The problem is the mechanic said the "left" mount is good. I bought the mount after someone told me that it was most likely my problem, now I'm stuck with it in my trunk. I suppose I could just tell him to put it in and work from there.
AccordCodger
05-03-2004, 01:50 PM
I wonder why the mechanic said it was good? You can't even see it, never mind judging whether it needs replacement by looking at it.
bx10466
05-04-2004, 07:39 PM
For my info, how was he suppose to check it? I wasn't there when he checked it, but I want to be there when he does it again.
AccordCodger
05-06-2004, 12:27 PM
I described that in my earlier response above.
bx10466
05-07-2004, 07:37 PM
Ok I Do Understand About The Ac But Physically When I Make Him Inspect It Can You See A Problem?
AccordCodger
05-10-2004, 02:12 PM
Well, I haven't looked too closely (on the car) myself, but as far as I can tell it's all but invisible (buried between the motor and the firewall). And having seen a (new) mount, I can't think it would be particularly obvious if it was bad.
dumpedwagon
05-11-2004, 01:56 AM
I argee, it looks like a big piece of rubber between metal...i guess a motor mount is rubber! But...????
AccordCodger
05-11-2004, 08:03 AM
Actually the left motor mount is pretty complicated (especially if you have auto trans - then it has a vacuum connection). The front one is easy to see and IS a chunk of ruber between metal, but it's the left one that is usually to blame for vibration.
bx10466
05-12-2004, 07:43 PM
Thanks guys, I still have the left mount and I'll just have him put the thing in. I need a tune-up anyway. By the way, does anyone know where to get the rubber that's between the door and the window? Besides honda... :nono:
