Suggestion on set-up please..
420aracer
04-26-2004, 12:16 AM
Hello,
New here on the forum but not the biggest novice you have ever met in car audio. I do, however, need some attention to this issue I have. Here are my specs -
Deck - Pioneer DEH-P6600
Components - Pioneer TS-C160R - 6.5" w/ 1" tweeter - rated 60W Nominal/250W Max - 4 Ohm
Rear - TS-D690R - 6X9" rated 80W Nominal/330W Max - 4 Ohm
Sub - (1) TS-W125C - rated 400W Nominal/800W Max - 4 Ohm *Maybe (2) later
Amps - ? (wanting Power Acoustik because they will be given to me)
Wiring - ALL Stinger components - HPM Series Digital Fuse Block, Ground, Dream Series RCA's and all wiring (4Ga. Wiring to Fuse Block, 8Ga. to Amp(s) and 4Ga. for Ground)
That is what I have ready to install. I have one problem .. what amps to get to maximize sound and usage of speakers in full watts without blowing them? I bought all the above but will be given the amplifiers. One catch, I will be given Power Acoustik amps. I have looked them over and if I had to choose, I like the new LT series.
Question, with the above hardware, what would be the best two LT series amps to get? I need (1) to appropriately power the 6.5" Components and the 6X9"'s and (1) for the Sub(s).
Please help me.
Thanks!!
Jeff P.
aznxthuggie
04-26-2004, 01:23 AM
well your head unit is good, pioneer tends to lag a lil with mp3s but its ok, the speakers are good, im using the 6.5 ones right now, the treble n mids are really good, the bass coulda been better, and as for the 6x9 i've never heard them, but as far as pioneer goes, the highs n mids should also sound ok, and i suggest instead of buying 2 amps, buy one amp for both speakers (it'll cost the same anyways) find a 50 or 60 rms x 4 amp, which should be around $160-$220, depending on what brand, and as for the sub i've never heard pioneer subs, sorry can't help with that
