need audio wiring help
dirtydx
04-24-2004, 02:56 PM
does anyone have the wiring conversion chart?? from Honda to typical?
i found one, but im leftover with two wires, Red w/ Black Stripe, and White w/ green stripe.
thanx
Akid
04-24-2004, 03:25 PM
thanx
the white with green stripe should be a speaker wire, the red with black stripe im thinking is one of your power wires..........
dirtydx
04-24-2004, 04:05 PM
nope the white with green stripe isnt a speaker wire.. i checked all four corners.
thats the only wire left, and i dunno wtf to do about it.. cuz on the decks harness, all thats left is the blue and blue with white stripe. which is for power antenna and amp i think...
white with green stripe what is it???
dirtydx
04-24-2004, 04:15 PM
Nope, still not working...
I need a 4thgen diagram.. or help. i keep blowing the fuse too.
Red with Black Stripe
White with Green Stripe
travagliante
04-24-2004, 09:37 PM
blue with white stripe goes to antenna or remote connector.
red and black goes to illumination,(service manual says lighting switch)
white with green goes to....
um are you sure its w/grn stripe. Because the service manual doesnt have it in it. Or coded at least. Try hooking it up to the mast
But if it blows a fuse you have to have a wire crossed somewhere because the 2 unused wires have no prwer going to them!!! Im guessing your power is touching your ground or a piece of metal in your car.
travagliante
04-24-2004, 09:40 PM
Here Is A Service Manual Diagram::
http://files.automotiveforums.com/gallery/watermark.php?file=/503/100270stereo.JPG
dirtydx
04-24-2004, 09:42 PM
but what exactly is illumination?
i dont need the blue and blue with white on the deck harness right? all thats left over on the decks harness is red... i tried connecting it to red with black, but nothing.....
yeah im 100% sure its white with green... ill try connecting it to Red. but what wire should red with black connect to?
dirtydx
04-24-2004, 09:44 PM
i dont have a yellow with red... could it be because its hooked up to the alarm??
travagliante
04-24-2004, 09:55 PM
NO NO NO NO
Illumination is, you know when you turn you lights on and the clock and ac/heat controls, the light can be adjusted on the wheel on the dash. Thats illumination. What kind of stero is it?
Lets try this differently.
Did you get a diagram when you bought the harness?
Well if you didnt heres what will do.
Keep the stereo speakers hooked up as normal.
Run the black wire to a ground on the chasis.
Run the red wire directly to your battery.
Run the yellow wire to a switched 12+ from the ignition.
Forget about the other crap. You dont have power ant. or illm. isnt worth even hooking up unless you want to ( orangew/white stripe to red/black). If you have a amp hook up the remote wire(says what color on headunit) to your amp or changer,etc.
That should be it. It will be the GHETTO way to hook it up. But since you cant get the connectors worked out this will work.
also check out www.the12volt.com, if you have any more problems, they are usually good about helping.
dirtydx
04-24-2004, 10:00 PM
its a Panasonic..
im using the stock wiring harness tho.. man im even more confused now..
dirtydx
04-24-2004, 10:04 PM
no the deck harness doesnt have an orange, so i just leave red with black alone?
white with green must be my switched 12+
travagliante
04-24-2004, 10:08 PM
no the switched is usually the same in all cars. Is there a diagram of the stero colors or wires on the headunit?
travagliante
04-24-2004, 10:12 PM
do you mean you are splicing the stock connectors.
go to www.panasonic.com click support in upper right hand corner and download your model numbers operating manual.
dirtydx
04-24-2004, 11:28 PM
yeah spliced onto the stock connectors.. i hooked the white with green up to the switched 12+, and it worked.....
cept i think this deck is drawing too much power, the signal lights were going twice as fast... couldnt even turn the car over..
its hooked up to two 6.5"s.. more troubleshooting
amy@af
04-24-2004, 11:29 PM
white w/green is most likely your constant power. yellow wire on the panasonic. your ignition most likely yellow w/red. it would go to the red wire on your panasonic. ground is black. black w/red is Illumination cap it off, it is not being used.
red w/ green (+) & brown w/black (-) is your right front speaker. that is the gray (+) and gray w/ black (-) off the panasonic.
blue w/green (+) & gray w/black (-) is your left front speaker.
just in case your car has rears:
(not to be confused with above in bold) red w/yellow (+) & brown w/white (-) is your right rear speaker wire. that would be purple & purple w/black off the panasonic
blue w/ yellow (+) & gray w/white (-) is left rear. which would be green & green w/black off the panasonic
if running amp:
use blue w/ white wire from the panasonic to the amp.
any other wire not being used, cap off and be done.
i asked jer (a MECP cert. 7 yr installer) :worshippy
dirtydx
04-24-2004, 11:50 PM
there wasnt a yellow with red though... that was my problem..
i think the previous owner relocated it for alarm
i ran the +12 volt battery wire to white with blue stripe
and the +12 volt ignition wire to white with green
dirtydx
04-24-2004, 11:55 PM
do you think i should switch the two around?? how can i tell if its not right? because when i tried to start the car, it was like completely sucked dry of power, clicking away..
