1.8 liter Distributer
vegas-v10
04-22-2004, 10:13 AM
I need help with a 1992 Plymouth laser. I car died on me last week in a parking lot but I was able to start the car and drive it home in the rain. I thought that the distributer was wet or something so I let it sit for a day. I tried to start the car the next day and I had to 'wind' it up for at least 10-minutes. It then started and ran for about 5 minutes and then died. I pulled a plug and tested for spark, nothing. I hauled it to a Import mechanic and he diagnosed it as a bad distributor. $860.00 and $200.00 to install. I hauled the car back home because that seemed pricey. I ordered a re-manufactured distributer from on-line for $280.00 and installed it myself, without disturbing the timing. Still no Spark to the plugs. I read up on the distributer and the power transistor, coil, and Crank angle sensor are all inclusive within the part. I pulled the fuel line from the rail and it pumps when cranked. There is just no spark. I pulled all of the fuses and they are fine. I talked with the mechanic and he told me that it can not be the Computer, it is the distibuter and he went on to say that 80% or re-man. are junk. Hard to believe. ANYBODY have any suggestions or trouble shooting?? The car is just a driver to work but is in excelent condition and used to run great. I am somewhat knowlegable about parts and installation but electronics ARGE!!!
Thanks a bunch in advance.
Import2nr99
04-22-2004, 10:24 AM
hard to say on eht quality of the rebuit distributor. I'd check out the coil pack.. could be a problem there. how are your plugs? are they in good shape? also your wires. I know they're simple things, but often the simplest ones are the ones that cause the biggest problems. if all else fails you might have to fork out the cash for a mechanic to look at it. sucks... I know. but sometimes thats how it goes. Good luck with the ride though
vegas-v10
04-22-2004, 10:31 AM
Import:
I beleive the coil on the 1.8 liter is inside the distibuter. At least that is what all of the manuals say. I put in new plugs yesterday but not wires. Could ALL of the wires be that bad that I have no spark on any of them. The only thing that was ever diffrent on the car was that I was driving in the rain, because it rarely rains here in Vegas.
