1997 Explore 4wd Low Light Blinks
BLP
04-16-2004, 11:57 PM
After Car Is Started 4wd Low Blinks, Tried Moving Selector
Out Of Auto To 4wd High And Low, Indicator Light Will
Not Come On. 4wd Will Not Engage.
Opera House
04-17-2004, 12:54 PM
Two things. The transfer case is known to leak fluid from the rear seal. At this age I would drain it and refill anyway. When low on fluid the wet clutch can stick and give you the light. When I bought my 97 it had only about a pint in it when there should be almost 2 quarts.
If you ever get the flashing lights, it won't reset on its own. You have to disconnect the battery for a couple of minutes to reset the computer. My light hasn't come back on in over two years.
BLP
04-19-2004, 07:53 PM
Thanks For The Help. Very Little Fluid In The Case. Changed Fliud And Reset Computer, Doing Fine.
Rickontheradio
07-04-2004, 12:30 AM
This sounds exactly like a problem we're having with my son's 97 Explorer. Will try your suggestion this weekend and let you know how it goes. Thanks AF, ETC.
