egine to choose from
artic84
04-14-2004, 05:32 PM
hey guys
just got an 98 240 mon. i have been thinking about what to do next. im trying to descide between 2 motors. rb26dett or the 2jzgte. i have 10k to spend. please help me make up my mind
mrflip69
04-14-2004, 05:59 PM
RB26DETT... simpler to put in than 2JZ, though they both cost about the same to install (assuming you keep twin turbos on RB26) If you're going to go single with RB26, might as well get the RB25, up to you. Keep in mind, if you want to use the 2JZ, you will need parts from a 1JZ engine, unless you're willing to pay for everything else needed for an entire 2JZ swap.
People will most likely tell you to go SR, and if that's an option... 10k will get you a finely built SR with change to spare.
Depending on your power goals (since you obviously have the money), research the other engines and see what fits you best.
98 240 huh? Nice find, and good luck with your project.
P.S. You plan on doing the labor yourself or having it done at a shop? I see you're in Georgia... check out Unstable Hybrids (www.uhrp.com) if you haven't already for more swap info.
TheLogikal1
04-14-2004, 09:05 PM
wow, 10k is alot of cash..
rb26 is nicer than he 2jz in my opinion....
but if i had hat money, id spend it on a 270r motor or a sr20 toda race engine and have some cheddar to spare for suspension
Ace$nyper
04-14-2004, 09:08 PM
yea i'd just get a build SR20 myself maybe get the 2.2 liter kit bigger turbo cams sleaving you know teh works
NSX-R-SSJ20K
04-15-2004, 05:48 AM
i agree with ace and logikal
HondaOz
04-15-2004, 06:08 AM
I just started to get into nissan's and I must say that I HAVE no idea y i chose honda's for power, but anyways, nissan is the powerhouse like my friend said, so here is my question...
How would you do a sr20 gt-iR swap, what mods would you have to do or where can I GO to learn more about it, any tips, and also about how much would the hp improve from stock?
Thanks
Check my page
http://www.cardomain.com/memberpage/569777
stealthj
04-15-2004, 09:06 PM
Thanks
Check my page
whats a sr20 GT-ir swap, u gonna make ur car a 4wheel drive????
as for this threads topic, if i were to swap? rb26dett.
nissanfanatic
04-17-2004, 02:22 PM
RB25. All the power you will need in a little 240 especially if you keep it rwd.
