Warning lights flash..Windows don't work
rjm66
04-14-2004, 05:22 PM
Hi, I'm new here, hope someone can help. I have a 1995 Explorer XLT, it has a Command start remote starter/power locks installed. Here's the problem....On occassion my FWD, FWD Low, OD off, and Check engine lights will flash in any combination of 1, 2, or 3 of the above, usually FWD and FWD Low together and OD off. Currently it is flashing OD off and every now and then both FWD lights will flash a few times. Whenever this happens my power windows won't work and sometimes my heater stops blowing hot air. I finally brought it to a dealer, but they won't get a chance to look at it until at least tomorrow.
I bought it used in 2000, it has about 120,000 km on it. It starts and runs great, shifts smoothly even in -30 to -40C, never even had to plug it in.
Thanks for any help.
Very puzzled
Rob
Crissy
05-27-2004, 05:07 PM
Did you ever find out what was wrong? This is EXACTLY what has been happening to me and it's driving me nuts.
mm2
06-06-2004, 08:30 PM
Rob,
My daughter's car has the same issues as you mentioned.
any luck getting this fixed?
HELP??
MM2
Very puzzled
Rob
tommyredshirt
06-17-2004, 02:36 PM
I have a 95 Explorer Eddie Bauer. Just had the thermostat replaced, when I got the truck back the lights were blinking and the windows did not work. I am scheduled to take it back next week but if anyone experienceing this problem found a cause please let me know. I tried resetting the computer but that blinking 4 wheel drive lights did not go away and the Windows still did not work. Checked fuses etc. Very confused
panthony
10-23-2004, 10:14 PM
I also have a 95 Explorer that had all the symtoms as described in these report posts. After many hours of searching I found that the wiring on the back bottom right side of the drivers seat had kink in it. I cut through the wiring sleeve, seperated and straightened the two wires and re-taped them. Also made sure that the connectors were fully seated under the carpet. No more problems with the windows not working.
