~*~*~Custom Exhaust Tutorial~*~*~
Sk8er6811
04-12-2004, 12:36 AM
Step 1: Get materials, u will need 2 pipes (one that will fit in the other one), a dremel, silver paint (silver sharpie also works), paint pen, a file, sandpaper, a x-acto knife, glue, tape, index card, and putty. here are some pics of wut u will need.
http://images.cardomain.com/member_images/10/web/538000-538999/538396_1_full.jpg
Step 2: cut the pipes like so
http://images.cardomain.com/member_images/10/web/538000-538999/538396_6_full.jpg
Step 3: when u put the pipes together u will c there is a little gap... we can fix this witha cut peice of index card. after u cutthe index card u put it around the silver pipe and insert the silver pipe with the index card on it into the barss pipe.
http://images.cardomain.com/member_images/10/web/538000-538999/538396_3_full.jpg
http://images.cardomain.com/member_images/10/web/538000-538999/538396_7_full.jpg
Step 4: apply glue around the silver pipe to hold the index card and the pipe in the brass pipe. u might also want to use a lil krazy glue. DONT USE TOO MUCH GLUE.a little glue will go a long way. the glue is the lil ring that looks like weld...
http://images.cardomain.com/member_images/10/web/538000-538999/538396_8_full.jpg
Step 5: now is when u will use ur glazing putty. apply putty ontop of the glue joint that u have just applied.
http://images.cardomain.com/member_images/10/web/538000-538999/538396_11_full.jpg
Step 6: Now you must wait for the putty to dry. i wood give it a good 20 minutes. while u r waiting u kan get ur sand paper out.
Step 7: After the putty has dried sand smooth like so, also if u want u kan cut the pipe on a slant like i have done.
http://images.cardomain.com/member_images/10/web/538000-538999/538396_10_full.jpg
Step 8: Now that u hopefully sanded everything down with no problems paint the brass pipe black for the C/F look.
http://images.cardomain.com/member_images/10/web/538000-538999/538396_2_full.jpg
Step 8: Make sure the black is dry, now u kan do the silver area i used the sharpie b/c it was easier, and it fit nicely in tehre, but u kan also use silve rpaint if u need to. here is the final product.
http://images.cardomain.com/member_images/10/web/538000-538999/538396_14_full.jpg
http://images.cardomain.com/member_images/10/web/538000-538999/538396_13_full.jpg
Lemme know what you all think, i think it came out very nicely am going to use this on my next import i build.
Sk8er6811
04-12-2004, 12:48 AM
prolly a lil late to b expecting replies lol
youngdrifter_x
04-12-2004, 01:25 AM
not that bad man. I think the can is a little big for andrew. but it looks nice
Sk8er6811
04-12-2004, 01:46 AM
hey thnx for replying, it really isnt that big it is 1/4 inch in diameter and the tip is an 1/8 inch
86_SR5
04-13-2004, 12:16 AM
I use 1/4 for my cans and 9/16 for my tips.
86_SR5
04-13-2004, 12:17 AM
or the other way around.
BRM
04-13-2004, 12:26 AM
Nice tip.
By the way "u" is spelt YOU and "kan"...is spelt CAN. That was painful to read.
Sk8er6811
04-13-2004, 02:28 AM
Nice tip.
hehe sry thats the way it type online kinda a habit i guess, ill try to correct myself WHEN i catch it lol
also u think this kood make it 2 teh how to depository that would rock!
suprastar
04-13-2004, 12:29 PM
there is already a couple in the tutorial section and even though the can looks good your way seems a bit longer than them
mike@af
04-13-2004, 05:48 PM
Nice tip.
:iagree:
Blowncivic1320
04-13-2004, 06:32 PM
it is somuch easier just to get 2 different sized styrene tubes slide them together add a little plastic welder and paint...lol
CamaroSSBoy346
04-13-2004, 09:17 PM
Blowncivic1320, that sig pic is fuckin hilarious
86_SR5
04-13-2004, 09:34 PM
Mike, where can I see some more of your thunderbird?
hondaaccordboy21
04-14-2004, 12:46 AM
Can you show some pics of them on the cars?
