1988 F150 302fi
legendhusk
04-11-2004, 08:15 AM
When I am moving down the highway my truck wants to cut out on me. It is noticable just when maintaining speed but gets worse when I step on the accelerator. It is not evident when I am idling. I have changed the gas filter, spark plugs, wires, and I ohm'd the injectors with a meter and they were all comparable, though I am not sure if that means anything. The truck has over 100000 miles.
Thanks in advance for any help.
[email protected]
[email protected]
amac209
04-12-2004, 04:28 PM
a fuel pressure check would be a good place to start sometimes pumps will put out pressure but not enough volume so when fuel demand is high the pressure drops off and your truck starts bucking. a check of all the critical sensors is a good idea, if you have access to a decent scan tool this can be done fairly quickly, do a sweep test on the tps(throttle position sensor). but i'm almost certain you have a fuel problem, check the regulator for any leaks. if you can a good test involves installing a pressure gage and taping it to the windshield and going for a drive. pressure should increase when rpms do. also inspect the wires at the fuel pump, look for any signs of corrosion make sure the ground is clean and solid any extra resistance will limit the pumps performance.
good luck
good luck
ervinj
04-13-2004, 01:19 PM
I'd start with the basics, Tune up, esecially timimg.
ervinj
ervinj
mayville1
04-15-2004, 07:48 PM
Replace your fuel pump. I had the same problems with my 86 F-150 302
