need some 14g info. wastegate setting...
pasha
04-11-2004, 05:11 AM
hey guys,
could someone give me some specs on the 14g turbo that came in the eclipse. mainly what is the stock wastegate setting?
thanks.
thanks.
kjewer1
04-11-2004, 08:54 AM
Are you asking about the 14b or the 13g, there is no 14g. ;) 13g came in 1g Autos, and 14b came in 1g manuals. The 14b has a 9 psi actuator, and stock boost on the 1g is 11 psi.
pasha
04-11-2004, 02:05 PM
wops, 14b it is.. :)
.. so its 9psi? is there any way to bring that down to 6-7psi? im considering using the turbo for a custom project.
thanks.
thanks.
Import2nr99
04-11-2004, 03:31 PM
*shakes head* what kind of car are you using it on? 6-7 psi is a joke. if you're going to run that low you might as well get a super charger or just not get a turbo. this is of course my opinion... so you don't have to listen to it. the 14b isn't that big of a turbo and I doubt that whatever you're running it on will have trouble taking 9 psi... unless you're turboing a moped
ashah000
04-11-2004, 03:51 PM
Turbo a go-cart! :D
JoeWagon
04-11-2004, 04:32 PM
If you want a little less than a stock 14b, use a T25 or 13g. I don't know how you would change the actuator without replacing it. No DSM company would bother making one, so it would be custom is my guess.
kjewer1
04-11-2004, 04:46 PM
I believe the t25 has a 6-7 psi actuator. With some creative bracketry it may fit on a 14b, who knows. Or you could just use the t25. If this is for a 2 liter or smaller the t25 will be very efficient at 6-7 psi (its good to 15 or so on that displacement) and will spool very fast. The 14b would spool well to, but then youre using a 25 psi turbo in a 6 psi application.... BOth turbos use the same manifold and O2 housing/down pipe. But the compressor outlet is very different (and oil feed lines). Odds are the t25 will be easier to work with in that repsect.
EclipseRST
04-11-2004, 05:00 PM
Turbo a go-cart! :D
hey who took my idea... lol but i really am making one! i made a go-cart with a Ski-doo 440cc snowmobile motor last summer and that fucker hauled ass! now this summer i want to turbo it! :iceslolan
pasha
04-12-2004, 02:35 AM
the plan is to put it on a ka24e nissan motor. obviously 2.4 litter. i was thinking that the compromise between larger displacement and lower boost might work. im noot looking for high power numbers, just a little more. if i run it at stock boost on stock parts, things will blow... i know it for a fact.
and opinions are welcome, as long as they have reasoning behind them :)
thanks guys.
thanks guys.
EclipseRST
04-12-2004, 06:55 AM
sorry to get off topic but i have to post this up! since we were talking about turbo go carts... this thing would be tight as hell even tho its a scooter!!
http://files.automotiveforums.com/gallery/watermark.php?file=/503/102895561My_Whip.jpg
ashah000
04-12-2004, 08:15 AM
That thing is awesome!!!
I think I would be scared to drive that :(
pasha
04-12-2004, 10:28 AM
that is sweet. i also saw some vids of a gocart doing some serious burnouts and picking the front end of the ground... now thats power :)
anyhow, back to the topic :)
BoostedSpyder
04-13-2004, 01:15 AM
fuckin A that thing is SIIIIC!!!! intercooler and everything. i wonder if it has wheelie bars, and a parachute!!! LOLOL
back on topic, i think you are going to either blow your engine up because a lack of the will to do it right and strengthen everything internaly. exhaust all other options of upgrades and then boost that shit. :)
