A.T to 5 speed swap for civic
boarderbrad158
04-10-2004, 06:02 PM
how difficult would it be to get a 5 speed engine swap into a AT 99 civic?
IntegraB16
04-12-2004, 06:44 PM
I recently looked up the step by step process for the swap because i wanted to do the same thing to my G/F's car. I don't remember all the steps and/or where. But, I can tell you a few things.. You will need a pedal assembly with a clutch pedal, shift linkage, and some wiring knowledge. I'm sure there is some more to it. I can tell you this for sure. I decided not to do it because it was too much of a pain it a$$.
Tranzlogic
04-13-2004, 12:18 PM
You will need teh tranny of course, but other than that your gonna need
shift linkage
transmission mounts
the gearbox
shifter
a new center console to support the shift boot
clutch cylinder
clutch resevoir
pressure clutch lines
all hydrolic clutch plumbing
a new brake booster
Brake/clutch bracket assy.
clutch pedal cable
adjustable tachometer since your redline and shift points have changed
as you can see its a very frustrating process and is very costly... i will say the same thing i always say..IF you want a stick buy a stick otherwise just deal with what ya got...yes it can be done but is it really worth it...........
salbaje
04-15-2004, 12:37 AM
I have all the parts you need for the auto to manual swap I'm in NOrthern California
Tranzlogic
04-15-2004, 12:01 PM
all it takes is to find one thats been wrecked
