AIR DRIED BEEF DOG FOOD
Weight Question
KaMaKaZiPyRo
04-07-2004, 09:19 PM
Does anyone know which is heavier, a 95' ex civic or 97' eclipse gst?
CivicSpoon
04-08-2004, 12:04 AM
GS-T 4sho
Volume_Civics
04-08-2004, 01:08 AM
Thats kinda a dur.........queston. (not to be mean)
The eclipse is way heavier.
KaMaKaZiPyRo
04-08-2004, 12:58 PM
Ok thanx, i didnt know cuz i dont even have a car..im 15
Volume_Civics
04-08-2004, 09:18 PM
Buying a new car?
KaMaKaZiPyRo
04-08-2004, 10:14 PM
ya, so i got all these Q's
snowman2005
04-08-2004, 10:19 PM
eclipse have bigger engine=heavier car
integra818
04-09-2004, 02:41 AM
Eclipses weight around 3000 LBS, the Civic Ex weighs less than 2400 lbs.
KaMaKaZiPyRo
04-09-2004, 02:11 PM
Ok, so will the civic still be lighter after a b18c swap?
snowman2005
04-09-2004, 03:34 PM
yes bc the chassi is lighter to start with. the only way u might weigh more than an eclipse uis if u mayb put in a H22 idk. y does it matter which is lither.
DeleriousZ
04-09-2004, 03:57 PM
lighter is faster, better handling, and has better acceleration.. if that's what you're asking... i think i deciphered most of that post correctly:eek7:
jcrx
04-09-2004, 04:01 PM
H22 only weights about 60lbs more than I b series, which only weights about 85 more than a D. The only way to make a Civic heavier than a Eclipse is to put in a competion stereo system, and give Rosie O'Donnell a ride to Burger King.
KaMaKaZiPyRo
04-09-2004, 05:16 PM
lmfao, ya I was wondering wich was lighter for speed snowman, another question, would I have to ake nething out like a/c or nething when i swapped in a 97b18c?
integra818
04-09-2004, 08:48 PM
IT's not always weight. Eclipeses have an engine that can go up to 450 HP before you need internal mods, the B-series won't be able to take that much power from the stock block. If you're tring to get the lightest possible car and you thikn you'll win just by bieng light, then get a 91 Ford Festiva, they weigh about 1700 LBS...they have only 60 HP but it's ok...your lighter than whoever you're racing so you'll win. What I'm trin to point out is, the Eclipse may be heavier, but it has one hel of an engine.
The fastest street legal Honda runs about high 10's, the fastest street legal eclipse I've seen does high 8's. Think about it.
snowman2005
04-09-2004, 08:58 PM
i think that honda engine are best engineered engines. mainly bc they pull alot of power for their size and components
KaMaKaZiPyRo
04-12-2004, 04:02 PM
Hey integra818 what engine is that honda that runs 10's running on? Because im getting and integra type R swap.
integra818
04-14-2004, 03:09 AM
There are many Hondas running 10's. Only a handful are doing high 10's or low 11's in street trim. But when it comes to 10 second Hondas, theres plenty of dragged out Hondas doing 10's, even 9's.
KaMaKaZiPyRo
04-14-2004, 01:24 PM
Reason I was asking was because ive seen in a video a civic run 8.3..sumthinand i wasnt sure what it had, i think it had twin turbo, im not sure.
B1SiR6A
04-14-2004, 02:13 PM
Street legal twin turbo civic running low 8's :rolleyes: guss thats somethin I just gotta see
KaMaKaZiPyRo
04-14-2004, 10:52 PM
Ya i dl it from kazaa if i find it again ill try to send it
IntegraB16
04-16-2004, 07:39 PM
How are you going to get a twin turbo out of an engine with only one exhaust manifold?? Unless you do some serious fabricating. Even then, only 2 cylinders for each turbo is barely enough pressure to make the turbo spool up.
jcrx
04-17-2004, 07:37 AM
Actually besides that, you can run one to feed the other.
There is no street legal 8 sec. Honda.
thepolishmafia1337
04-17-2004, 09:34 AM
is it possible that someone doctored the video?? you know that 75% of what you see on the internet is false, 25% is theory.
jcrx
04-17-2004, 09:45 AM
I theorize that your statement is false, of course, that's based o your statement.
B1SiR6A
04-17-2004, 12:34 PM
...LoL...
MexSiR
04-17-2004, 12:56 PM
By the way, what does the famous hb civic that "cheesefrog" dude has, isnt he running high 9s or low 10s? Ive seen a video of him racing against a 10 sec viper and beating him. That civic is fu*ked up.
boosted331
04-17-2004, 06:11 PM
Cheezefrogs car was/is far from running 9's. When he raced the viper he was running some .5MM over 9:1 JE's, a T3/60-1 on an SFP manifold, STR intake manifold, can't remember which intercooler, hondata, and a 75 shot of juice. 430 WHP on 22 psi, without the juice. I havn't seen him around in a while, but his new setup consists of a T67 on a hytech manifold, with an AIR carbon fiber intake manifold....
