Sub seems to fuzz
maddogsback
04-07-2004, 09:46 AM
ok i got a 600 watt pioneer amp with a 600 watt sub hooked up to it. when volume is turned up the sub seems to just thump very little and fuzzes and makes a terrable sound. what is the problem because the sub is brand new and i want it to thump and it will just crackle and fuzz. Any input on the situation would be greatly appreciated because i need it to work. could it possibly be the amp or what?
PaulD
04-10-2004, 01:58 AM
sounds like you done blowed up the sub. Here's a test, while palying at low to med volume - push the cone in slightly. If the razz goes away, the speaker voice coil is blown
maddogsback
04-13-2004, 09:26 AM
No problem i fixed it. wire was loose. hooked it up right and it works great thanks.
:iceslolan
