Oil sending unit going off
integra111
04-06-2004, 11:02 PM
My oil sending unit has been going on and off for the past couple months. The oil level is fine. What could be the cause .
Thanks...
Thanks...
i_a_n112784
04-06-2004, 11:27 PM
Try changing the oil pressure sensor. I don't know what car you have, but on 88-91 civics it's right above the oil filter, and has 1 wire going to it. I'd imagine it would be around the same area in what ever you have.
integra111
04-07-2004, 11:57 PM
Ok.. i just now installed a new oil pressure sensor.
The damn thing is still going off! Could it be i need new oilpump. Any suggestions. PLZ...
i_a_n112784
04-08-2004, 11:19 AM
Since the oil level is fine, a loose wire or the oil pump are the last things I can think of that would cause that to go on.
integra111
04-08-2004, 11:46 AM
OK. so if the oil pressure switch is working properly it would be going of cause the oil pressure is very low, correct? What causes the oil pressure to be low. Probably a bad oil pump, not sure what else. Im going to change the oil and see if that does anything.
integra111
04-08-2004, 10:31 PM
If i get higher viscosity oil will it raise my oil pressure.
