Re: 100+ Hp easy???
1989_cash_eater
04-04-2004, 08:58 PM
I was wondering if instead of a MPFI conversion, I would gain 15-25 Hp
by installing a header, exhaust system (from the cat. converter back),
and a big custom air intake using a K&N cone air filter? I already have
bosch platnium plugs, bosch OEM plug wires, a new O2 sensor, and I use
Lucas oil treatment for restored compression. The motor is the orignal
D15B in my 1989 DX Hatchback (5 speed manual) with about 229,000
KM (roughly 144,000 miles). I would do the MPFI if it were easy to get
the patrs here. Anyway, can anyone help me with this? Thanks.
91civichatch2571
04-04-2004, 10:01 PM
You wont really get much of a gain when you put all those parts on with dual point injection. Only when you go mpfi will you get the better gains off your bolt ons. You could get an mpfi wherever you live, your just gonna have to get someone to ship you the stuff. Its the best way to boost your power
girlsrace2
04-04-2004, 10:29 PM
Actually I have a mpfi manifold for sale if your interested. 60bucks shipped
travagliante
04-04-2004, 11:45 PM
with that you should have no problem being over 100 hp.
but the mpfi swap would be a crutial point though.
Look on ebay. a pm6 computer usualy aroun 20-40 bucks. And a mpfi manifold from any civic varies 10-100 bucks. And get 4 88-91 civic ex/si injctors and a injector resistor box.
integra111
04-05-2004, 02:27 PM
just buy a faster car
integra111
04-05-2004, 02:28 PM
Why mod that terribly slow engine
1989_cash_eater
04-05-2004, 02:46 PM
Thanks for the info and advice. I really thought about the MPFI conversion but there's no one around here that would be able to do it for me (without paying a fortune).
nemo_wolf
04-05-2004, 03:54 PM
do you have any experience with a soldering iron? If your still in school try taking an electronics class, pay attention and practice all you can. Once you got this down you can do most of the wiring work without a problem.
As for tools and such, someone else could probly tell you if you need something not ordinarily used to work on cars ... but just about any standard tool box should work to do it.
Parts, well dude up above already said that he has parts for sale.
If your willing to put some time, study, and effort into it you can do it on your own if your comfortable with it. It would also be best if you had some mechanic friend or backround ... but these are terrible easy cars to work on compared to some of the euro cars where you have to take about most of the engine to get at that one part way down in the middle.
1989_cash_eater
04-05-2004, 07:01 PM
I can solder, but i'm kinda afraid that i'll screw up the electronics parts (connecting the ecu and injectors) because it's currently my only ride. By the way, do I need a different ECU, or can I modify the old one?
GTA
04-05-2004, 07:10 PM
you need a 88-91 civic/crx si ecu. the code for it is PM6.
girlsrace2
04-05-2004, 07:56 PM
Did I mention the manfild has, 4 injectors, fuel rail and throttle body
lilol89crx
04-05-2004, 09:46 PM
dont forget either an hf or si dizzy.
