Trouble Codes?
bigbrd
03-24-2004, 02:28 PM
My 95 5.0 HO is putting out an 181 and a 189 trouble code. According to the book that means the system is running rich. Where should I start testing sensors? I have adjusted the timing and it is correct. The car has never run right. It feels like it it just won't get up and go.
stang_racer20
03-24-2004, 10:11 PM
O2 sensors and the ECT sensors are the biggest factor to the a/f ratio.
price111
03-30-2004, 07:55 PM
The above are good suggestions. Might want to check your TPS voltage, too. Closed it should be less than 1 volt - somewhere between .90 and .99. I run mine at .98. You will need to probe the wires. It's a three wire hook up and, as I recall, it's the green and black ones?? Running rich does sound more like 02 sensors, though. Or, you cats could be clogged, too.
