96 Grand Voyager wipers on, switch off?
aerialimage
03-23-2004, 09:07 PM
Ok I have two 96 Grand voyagers and both seem to have the same trouble!
My van has just started cycling the wipers uncommanded as well as not always parking after turning the switch off!
my wifes 96 has had the wipers running on their own for almost a year now! they come on intermittently! Anyone have this one?
Thanks friends!
Thanks friends!
ijustice
03-28-2004, 10:01 PM
I've had the same prob with my 96 voyager for a couple years now where the wipers will just come on by themselves, I think it's a loose connection in the control because when i twiste back on the control to put it more in the off position the wipers stop. Would love a solution to this prob that I could fix myself.
Nr1Skier
04-08-2004, 11:24 PM
yea my dad has the same problem but with the rear windshield wiper, also had trouble w/ a.c. , car wouldnt sart had 2 replace the computer and about a year late now, it wont sart again. (sry about my punctuation)
slantsixness
04-22-2004, 01:19 PM
the ghost wipers are common. Don't worry about it. It's just annoying, but you could get a worse wiper motor new in the box too.
The contact ring in the motor that sends the wipers to the 'home' position is dirty, if you tear it apart and clean it, it'll work right for six months or so and start it again.
everybody has this trouble.
Slantsixness
Slantsixness
Anaudiophile
04-26-2004, 12:23 AM
1996? Multifunction switch!
tasteph
04-28-2004, 04:15 PM
Hey I used to own a '97 Voyager and had the same problem. Every once in awhile the wipers would make one or two swipes, really strange!
Hmm.. "ghost wipers", I like that term.
timd
04-29-2004, 12:17 AM
What about the wipers coming on when the turn signal is used?
slantsixness
04-30-2004, 09:43 AM
Timd,
Turn signal with wiper problem is the bad switch.
Ghost wiper problem doesn't relate to that, as whether they're on or off they just start wiping, or wipe more than once (sometimes lots!) when in pulse, stop in the middle of the windshield, or don't come on for the second or third timed pulse etc. Normally, we all grab the wiper control to try to undo whatever's gone wrong, but it clears up before we get to use the switch, hence Ghost Wipers!
This is also not related to the "clockspring" recall where your cruise control, horn, and Airbag all go screwy. Diam-Chryco will fix that for free... even out of warranty, no matter how many times or how long it is.
It's not a Bug it's a feature...
Slantsixness
Slantsixness
rdaniel911
05-12-2004, 06:26 PM
My wifes 96 has done the same thing, according to dodge it is the power distrubution module, (the fuse box under the hood and it's computer that cost 250.00 plus programing and installation fee) that is causing this problem.
slantsixness
05-13-2004, 09:00 AM
rdaniel911,
If you change the "power distribution module" under the hood and paid $250.00 for a "fuse box" you have just been bent over dude.... sorry.
It's not the problem.
Why would you still take a '96 to a D-C Dealer, anyway?
Oh, I see... you're a Ford man.....figures...
I'm not trying to be mean, they tried to tell my wife it was the body control computer in '97, and they wouldn't cover it under warranty, and, upon further investigation, I found that this eventually became a common problem, and the slip ring (home) switch in the wiper motor was the trouble all along.
save yourself the money. You can live with the Ghost wipers, they don't screw up that often.
Nr1Skier
08-10-2004, 06:15 AM
Aight computer was replaced, but more problems are occuring.
rsolock
09-26-2004, 05:00 PM
I am also having the same problem with the ghost wipers, but I am also having a ghost radio problem too. The radio display won't light up anymore. The radio itself comes on when it wants to, it will turn off when it wants to, I can't control the sound or anything. It just scares the living heck out us when it just comes on out of nowhere blaring and we can do anything about it. It will sometimes play the radio or a tape at it's convenience. When I turn the car on it does make sound like it is turning on. I replaced it with another radio, but am having similar problems with that one too. Could this problem be related?
vipergg
09-26-2004, 09:25 PM
This is a common problem with many TSB's to fix this , first fix is replacing the turn signal stalk . If this doesn't work then replacing the wiper motor will fix it . Have never heard of this being any kind of computer problem . Did see one fix being a bad ground somewhere but don't know where .
jgionet
10-12-2004, 07:37 PM
well.. at least I'm glad to hear (in a way) that I'm not the only one with this problem too :)
now I just have to figure out why one of my rear windows will only open once in a while.. faulty motor? bad switch? I replaced the motor with one from a wrcking yard.. and that one works a little more than the original... DOH!
