Airbags and other questions.
fsfjs1
03-20-2004, 03:29 AM
I am rebuilding a 95 and have to replace the airbags. Also i have to replace the airbag module. I believe that there are three sensors in the front of the car, but i havent found the module yet. Anyone know where it is? Also, what is the best way to replace these airbags? My heater motor isnt working either, could this be a result of the airbag going off? I have checked all the fuses and they are ok. Does anyone know the horsepower that these monsters create? My first step is to check whether mine is an autobahn or not. One last thing, there is an abundance of different style wires and clips in the center console, are these to a stock option of some sort? The car runs good and I am debating whether to sell it or keep it for myself, it has 110k on it, but clean. Any suggestions in any areas? Thanks
Keith1
03-20-2004, 04:59 PM
Airbag module is under the carpet below the passenger front seat. The part number is 9378216. The front impact sensor is located on the passenger side front frame rail. You might want to double check but I think you will find only one up front. The module will give you a signal code by blinking 8 times before the light goes out indicating the loop is functioning. If you haven't done this before you might want to do your component installation and have someone else scan with the bags bypassed using a test resister.... Or Have someone your'e not very fond of start the car for the first time... Airbag components aren't very difficult to replace, knowing that the car will function again as designed, is the real hard part.
The other questions you have asked can be ansered by searching the archives.
Keith
Keith
fsfjs1
03-20-2004, 08:17 PM
I actually found three sensors in the front, left, right and center. Do these need to be replaced after the deploying of the airbags or just the module?
Aurora3.5
04-07-2004, 08:59 AM
Check out http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2470876185&category=6783 Got an Airbag module for a 95 from a parts car. L8r!
Also Check Out here: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2471808306&category=6783
cdman3d
04-07-2004, 09:18 AM
Go to www.intellichoice.com, you can search the used car section and find exactly what any car comes with stock HP!!
