body kit
nicholas9walter
03-18-2004, 10:54 PM
i have a blitz kit and i bought it for my 95 rs which is for sale, i was wondering if it will fit all years? the reverse lights are closer to the licence plate and i know they sell them extended further out too. i was wondering if there was a difference. I'm not sure if the 97 headlights would fit the front end either because i know the 97 and up headlights don't fit the 95 front end.
Import2nr99
03-19-2004, 05:20 PM
it's all a matter of what year vehicle the kit was molded on. 90% of the time the kits are molded on the 97-99 year vehicles and you need to do the upgrade to the 95 and 96 yr models. the wholes in the rear part of the kit can very easily be glassed over and moved to compensate for the change of position. it will only take an hour for someone experienced with fiberglass to do this. The best way to find out, if you have the time or are really bored, is to remove one of your headlights and test fit it on the front of your kit. if your headlight lines up correctly, then you have a kit made for the 95-96 models. if there is a gap of about 1/2 inch to 1 and 1/2 inch around the inside area of the headlight, the kit is molded for the 97+ vehicles. Good luck
