need firing order
smiltstomb
03-18-2004, 02:28 PM
for a 84 camaro Z28 most prob no its the 305 HO any help id appre.
DaMoNe6969
03-18-2004, 04:02 PM
I believe its 1-8-4-3-6-5-7-2
Driver side cylinders (starting from front of car
1 3 5 7
Passenger side are
2 4 6 8
1 3 5 7
Passenger side are
2 4 6 8
89IROC&RS
03-18-2004, 08:29 PM
bingo
smiltstomb
03-18-2004, 08:30 PM
thanks man
Konza
03-18-2004, 09:22 PM
Yep, been that way since 1955.
smiltstomb
03-19-2004, 02:11 AM
huh i didnt know that im new to camaros been wanting one for a while but just found this 84 for 400 bucks and couldnt pass it by thnx again for the help
zboom86
03-29-2004, 05:42 PM
I got the firing order for the spark plugs but how do u know were to start on the distributor cap?
1992RS
03-29-2004, 05:50 PM
looking at the distributor from the front there will be two posts on the front, 1 is the one to the right.
zboom86
03-29-2004, 11:40 PM
thanks all try that
zboom86
03-30-2004, 12:16 AM
almost
so when i look at it there is a center post but I went with the one on the right. From there i went 12345678 to the right is that right? But it almost fired right up. I just put a new battary in with new termanals. And I'm geting new spark plug wire set Wednesday.
amac209
03-30-2004, 12:26 AM
change the wires one at a time then theres no room for error
zboom86
03-30-2004, 12:36 AM
this is my Baby 1971 Camaro with 350ci with hurst 4-speedhttp://files.automotiveforums.com/gallery/watermark.php?file=/500/164809Picture_0045.jpg
zboom86
03-30-2004, 12:51 AM
That is the problem i all ready toke them off I'm new at this
amac209
03-30-2004, 02:13 AM
The order is 1-8-4-3-6-5-7-2
1 3 5 7
Passenger side are
2 4 6 8
the distributor has a clockwise rotation i believe the terminal for #1 points towards the front passengerside headlight. line up the timing marks on the pulley with the pointer on the front cover. if the engine is on the compression stroke the rotor should be pointing more or less forward. now it is pointing right at the terminal for cyl#1 on the cap. now plug in the remaining wires following the #1 wire in a clockwise pattern for 8-4-3-6-5-7-2. if you can't figure all this out look at another chevy with a small block and hook them up the same way. good luck!!
1 3 5 7
Passenger side are
2 4 6 8
zboom86
03-31-2004, 08:22 PM
Ur the shit dude it worked shes puring again Thanks
