Throttle issue
markbaham
03-17-2004, 10:41 AM
I have a 125 Suzuki ATV.... When I throttle it any, it dies. But, It will idle fine. What's the deal.?
MagicRat
03-29-2004, 10:51 PM
The main jet in the carburetor is clogged. Its easy to fix. Remove the carburetor and carefully unscrew the float bowl. You can see the main jet. It should have a needle attached to the throttle slide that goes in and out of the main jet when you open the throttle.
Spray some carb cleaner into the main h=jet and also around the float bowl to clean out any residue.
Then reassemble.
You might want to get a service manuals so you can see instructions on how to properly remove and disassemble the carb.
