h22 with f23 tranny?
Hatrick101
03-14-2004, 11:51 PM
anyone know if an h22 motor will fit right on a f23 tranny? And would I have to change the axles? Im pretty sure ECU has to be changed.
chuckhatch
03-15-2004, 09:09 AM
yo im pretty sure the f series trannies will bolt up to an h22a but u will have change out the ecu..for sure
SRV BOY
03-15-2004, 09:14 AM
ya it should work, i had the original h23a motor with 2.3L tranny, i dropped an h22a motor in the car and just changed the ecu as well, and i have had no problems so far, i have had this h22a motor in now for a years time
crxlvr
03-15-2004, 08:06 PM
the f23 should bolt upto the block, with very minor to no modifiaction, but the ecu shouldnt have to be changed, unless its an automatic.
Hatrick101
03-16-2004, 12:01 AM
cool, thanks, cant wait put it in
Hatrick101
03-16-2004, 12:02 AM
actually another question. What about my exhaust? Can i keep it? I know header and intake have to go.
crxlvr
03-16-2004, 10:48 AM
your gonna need to have an exhuast shop weld the two parts together, they might not lign up correctly.
Hatrick101
03-16-2004, 08:48 PM
thanks for the info
killah_xft
03-17-2004, 01:38 AM
the exhaust... just get the header for the engine (H22 header) then get the exhaust system for the car... go to a shop like meineke, or Midas, and have them put in an extension if that is needed from the header to the Cat... should be an easy fix, and fairly cheap....
