fast turn signal
RickDaTuner
01-06-2002, 07:01 AM
I was just wondering if any knows why my left side turn signal blink like crazy before the used to blink normaly but now they blink like hyper blinkers its really annoying having one side slow and the other side super fast
the front and rear bulb are hyper white and have less than a weeks use on them plus a hyper white side marker which ahs been in for like two months also when I trun on my hazards the front bulb alternates with the marker and the rear bulb its weird it just started daoing this and it worries me that it might do something to the car
can anyone give me some advice and feed back
thanks
94civic
01-06-2002, 11:50 AM
check if your bulb is in good or it might be sign that the bulb is about to go.
EliteAccordPH
01-07-2002, 12:55 AM
Is one of the bulbs dual filament that can cause it too.
Iceman43
01-12-2002, 07:33 PM
could be the relay that operates the indicators is up shit creek so get it checked by an auto electrician laterz
RickDaTuner
01-13-2002, 03:33 AM
all the bulbs are new like i said the fron one is a dual filliment liek all 92-92 civics do the marke is a hyper white single filliment and the rear is a single filiment hyper white to
im not sure if the relay dead how can i check it but first of all were is it? i think if it was the that though bolth the left and right one would be doing it
Beyond Imagination
01-13-2002, 04:31 AM
The loose bulb on my Civic after rear ending some guy cause my signals to be hyper speed .. check your bulbs ...
Quetzolcotl
01-15-2002, 03:05 PM
if the bulbs are all ok and you cant figure it out otherwise look at the info on changing your blinker speed on www.jdmfan.com and see if you can just change out the resistor or something.
