Speedometer doesn't move
tomminajar
03-11-2004, 06:34 PM
speedometer doesn't work unless I drive it for an hour, then it will work till the next day. No codes so I guess the VSS is ok . Any Ideas??
91 3.1 v6 auto trans
burnM
03-12-2004, 08:09 PM
I had the same problem in my Caprice... it was a loose wire to the speed sensor. I just hope it's not a broken tooth on the sensor gear, some of them are plastic.
tomminajar
03-12-2004, 09:21 PM
Didn't you set a code (check engine light came on?)
my firebird has no code ...
FormulaLT1
03-12-2004, 09:28 PM
91 did they use vacuum line or cable for your cruise control?
FormulaLT1
03-12-2004, 09:32 PM
Also your trip and regular odometer aren't working right?
burnM
03-12-2004, 10:26 PM
It only throws a code once in a while(light)... shut the car off start it back up, goes away, reset the codes, a month later does it again. Sound familiar?
tomminajar
03-12-2004, 11:12 PM
No codes ever - No cruise controll Not an option - No speedometer -no trip- no odometer- no work - no idea- the vss is working I took the gauges out and cleaned the contacts it made it worse all the other gauges work ? it's a pissser...
FormulaLT1
03-12-2004, 11:42 PM
Is your speedo cable run or electronic wire harness? and if Cable did you check to see if the end is wound and ifs it electrical did you check fuse panel as well as use a voltmeter to check the signal to the speedo
burnM
03-13-2004, 12:44 AM
Don't forget the connection at the trans....
xlwhellraiser
03-14-2004, 11:14 PM
I had this problem on my 79 ta, but the source was that the line from trany was lying on the exaust pipe and got burned.
I am not sure if this is a problem on your bird, but its worth checking.
paul_allain
03-22-2004, 07:38 AM
Either A Bad Connection Or Your Gear In The Tranny Has Either Popped And Slid Back On The Shaft Or Is Stripped, Takes 10 Minutes To Pull The Vss To Check The Gears.
burnM
03-22-2004, 10:28 PM
Yeah...
Change the O-ring when you check it, or it'll leak after you put it back in.
