civic not firing
aaron7502
03-11-2004, 12:43 AM
hey - need some help here - I ahve a friend I'm trying to help with her 1992 civic. Car wont start. Car will turn over and fuel delvery seems ok, can smell fuel - but no spark - did new cap/rotor/plugs but when I pulled the plug and cranked the motor no spark that I could see - what else should I look at? Any kind of relays? Do the coils fail on these cars?
Thanks in advance! Aaron
GScivic7
03-11-2004, 03:30 AM
check the igniter and plug wires.
kona10
02-10-2005, 01:37 PM
I'm having the same problem. Replaced the plug wires and it ran fine for two miles then it just quit. Not getting any fire now. Any further Help?
typerx7
02-10-2005, 07:55 PM
yes the coils do fail, i have posted this maybe three times already lol...replace the ignition coil...i did the same, i coudl smell all the gas, i tested the plugs i raplaced the cap and rotor. even the battery! then i repalced the coil and it started up...
jeffseby
02-15-2005, 05:25 PM
A 92 civic. That can be anything, Caps, rotor, Coil, Plugs, Wires, Main Fuel Relay under the dash owned me!!...all easy fixes :thumbsup:
BIAR
02-15-2005, 07:04 PM
If the plugs are wet go for the coil.When the ignitor is bad it also kills the fuel.Carl
