stopped running
350crazy
03-08-2004, 01:43 PM
i was drivin my truck and then i hit a traintracks crossing at a high speed and as soon as i hit the bumps my truck shut off??? why is this???? please help and
Also does a head gasket or vavle cover gasket leak make the engine lose compression?? alot you think??
89IROC&RS
03-08-2004, 05:38 PM
as for the truck, did it just shut off, and then you could restart it?? or did it shut off, and now you cant start it at all????/
as far as the gasket issue, a leaking valve cover gasket will spill oil all over your manifolds, making a big cloud of white smoke. a leaking head gasket will loose compression, or blow out into your cooling system. mixing coolant and oil.
caw333
03-10-2004, 01:57 AM
What kind of truck? I know your in the chevrolet forums but then again your asking a truck question in the camaro forums. So if its a Ford you might of tripped the fuel shut off cause I know it don't take alot of vibration to shut it off and in that case you will have a reset button somewhere. Now if it's a Chevy then you might have a short somewhere. Not that chevys have a problem with shorts but anythings possible.
