throttle surge cont......
anarchy1114
03-06-2004, 05:33 PM
aiight peepz,
this is really pissing me off. all of u talk about throttle surge happening between 1200 and 1500 rpms. but my gs has throttle surge between 600/700 rpms and 1000/1200 rpms. it wierd it'll idle and then bounce to 1000 sometimes 1200 then jus drop to 600/700 rpms and i dunno what it is i've taken the slack out of my throttle cable, cleaned the throttle body and it still is happening. i've been told the the only 2 things remaining to check/replace is a vaccum leak somewhere behind the intake manifold and the tps sensor.
but how do u find a vaccum leak and if i do have a vaccum leak how do u fix it??
and about the tps sensor.... what do these damn things run to buy brand new??
thanks on any advice you can provide me with
ashah000
03-06-2004, 07:31 PM
Do you have a check engine light??
anarchy1114
03-07-2004, 01:10 AM
nope my check engine light hasn't come on at all. i dunno whats wrong with the car but tomorow i'm gunna clean my throttle body. if that doesn't help then i'm just going to ignore the surge altogether
EclipseRST
03-07-2004, 02:50 AM
while the car is running spray some starting fluid on and around the intake manifold to check for leaks! if the engine revs up then you know you have a leak, also spray all the hose connections, where the intake manifold meets the head, and any other connection that looks as if its vacuum related!
ashah000
03-07-2004, 06:59 AM
That is what I am doing, ignoring the surge.
But mine does not go down.
And just so you know it can be more than the tps sensor and vac leaks...
I am hoping mine was because of my egr valve, so i pulled that sucker out yesterday :biggrin:
