'99 SLT Outside Tempature Guage Inaccurate
NJGMGuy
03-05-2004, 09:08 AM
My outside tempature reading is always 'off' by +/- 5-8 degrees. Its more accurate in colder tempatures. Where is the sending unit for the thermometer located? Can it be calibrated?
Thank you
riptreeper
03-10-2004, 09:28 AM
You may need to reset your gauge. Do this by holding both buttons down until the number flashes then it should be reset. Also check your owners manual.
NJGMGuy
03-11-2004, 09:46 AM
...holding both buttons down until the number flashes then it should be reset...
When I reset, it goes into CALibration. This does nothing to readjust the temperature reading only the compass. Does anyone know where the sensor (probe) is for the temperature sending unit? Thanks Rip'
NowhereGMCMan
03-13-2004, 08:38 AM
I have a picture in my gallery of the location. It's under the hood, maybe explaining the temp. fluctuations, looks to be on the right side
forwars behind the radiator mounting. If you can't get into gallery
NowhereGMCMan
NJGMGuy
03-15-2004, 09:01 AM
[QUOTE=NowhereGMCMan]I have a picture in my gallery of the location.
Hi Nowhere' Thanks for your info...can you post a link of your website or a link to the Temp. Sensor location image? Thanks for your reply!
NowhereGMCMan
03-15-2004, 10:24 PM
Here ya go. If you you select "gallery", at the bottom of this message, next to "add buddy" you can get to the pic as well
http://files.automotiveforums.com/gallery/showgallery.php?ppuser=156610
