v6 swap
Brotje
03-04-2004, 01:11 PM
I have a 1987 firebird with a bad v6. How hard is it to replace the v6 with a 305 or 350?
Jm93
03-04-2004, 07:03 PM
new mounting brackets, new tranny most likely, it may be a bit much for someone to do at home, if you are inexperienced
Brotje
03-04-2004, 07:13 PM
Do I need to worry about elec. hookups and a new computer harness?
84and85bird
03-04-2004, 08:28 PM
You will need a computer from a donor vehicle, unless you go with a non computer controled carb.
Brotje
03-05-2004, 06:29 AM
I am going to dig into to the motor today. If I can fix the v6 I'll be fine. The car is for a 15year old and I am in no hurry to give him a v8. All I know about the motor right now is that it has a real bad oil leak towards the back of the motor.
84and85bird
03-05-2004, 06:18 PM
One thing to check if the oil leak is in the back of the motor is the o-ring for the distributer.
Brotje
03-08-2004, 01:14 PM
Well I am back and the oil leak turned out to be a hole in the oil pan. Right now (with fingers crossed) the car seems to be in pretty good shape. Hopefully it will be ready for the boy's b-day on the 16th. I need to fix the seats or most likey replace them and the car should be good to goooooo!
