Cant hear BOV...
RomainDeaMarchi
03-02-2004, 07:27 PM
When im driving, at high and any speed..i roll my windows down but cant hear my BOV when i shift..i have a turbo so shouldnt i hear that? Or does it release under the hood.
RiceRocket18
03-02-2004, 07:38 PM
you need to disconnect the diverting hose from the BOV. right now it's prob connected and divering the air back into the intake. also, is your BOV stock? if it is, then consider getting an aftermarket one before doing it.
RomainDeaMarchi
03-02-2004, 07:40 PM
Is that bad, or does it not really matter.
RiceRocket18
03-02-2004, 07:46 PM
what is
RomainDeaMarchi
03-02-2004, 07:49 PM
"right now it's prob connected and divering the air back into the intake"
That
RiceRocket18
03-02-2004, 07:50 PM
no it's not bad. it just diverts the remaining air back into the intake. doesn't really make a difference if you vent it out in the air.
RiceRocket18
03-02-2004, 07:52 PM
oh make sure you seal the end of the hose that's connected to the BOV so dirt doesn't get into the intake.
RomainDeaMarchi
03-02-2004, 07:54 PM
What could i use to do that? Can you buy something or does it gotta be homemade.
RomainDeaMarchi
03-02-2004, 08:10 PM
http://files.automotiveforums.com/gallery/watermark.php?file=/501/153360IM000371.JPG
http://files.automotiveforums.com/gallery/watermark.php?file=/501/153360IM000372.JPG
Just some pictures of the cap and intake..looks stock to me.
RiceRocket18
03-02-2004, 08:13 PM
http://www.automotiveforums.com/vbulletin/showthread.php?t=194614&page=1
and get rid of that stock plastic crap. it's no good for you :nono: :iceslolan
RomainDeaMarchi
03-02-2004, 08:15 PM
Haha Ok. Thanks for the help. I'll check it out
RomainDeaMarchi
03-02-2004, 08:28 PM
Can you take off the plastic cap and put a new one on? Or do i have to buy a whole new BOV?
RomainDeaMarchi
03-02-2004, 08:35 PM
The downside of releasing the air to atmosphere is that it has already been metered by the mass air sensor (MAS), and when it blows off the ECU will be injecting the wrong amount of fuel into the cylinders.(The MAS reads ten air units, say, and the ECU tells the injectors to squirt the right amount of fuel for ten air units.But then five of those air units are vented off to atmosphere, and only five make it to the cylinders, and five more have to be drawn from the outside air, through the MAS again) so the engine temporarily runs extremely rich, meaning too much fuel is injected into the cylinders.
This temporary rich condition isn’t usually that harmful, but it can cause bucking or hesitation on lift-throttle.If the condition is really bad it can eventually foul spark plugs and even clog the catalytic converter.(Unburned fuel on the cat burns very hot, and too much of it can melt the cat).
^ I read this from a site..what do you think?
RiceRocket18
03-02-2004, 08:37 PM
no debate.. get rid of that crap... a BOV will only cost you $200 :D
RomainDeaMarchi
03-02-2004, 08:39 PM
Only 200$!? Haha ok, thanks.
BoostedSpyder
03-02-2004, 09:35 PM
slow down there bucko [rice]... you won't hear your BOV at speed, i barley hear mine with the top down. as far when you are going slower, it will make the most noise going from 2nd to 3rd... venting the BOV isn't always the greatest idea. it can make your idle messed up and make you backfire too. and you already have a 1G BOV, no need to upgrade at all [well not for a while]. and it's funny [ricerocket] keep calling it a 'diverter' lol... whatever... [romain] you may want to look into a boost controller if you don't already have 1, and also a fuel pump upgrade, like a 190lph... as far as the intake pipe is concerned, make sure you do the dump tube hack, then look into aftermarket ones. if you don't know what that is look it up on http://www.vfaq.com.
RomainDeaMarchi
03-02-2004, 09:47 PM
Yeah i got a Apexi AVC-R II Boost controller..why upgrade the fuel pump?
BoostedSpyder
03-02-2004, 10:02 PM
with higher boost you need more fuel on tap to compensate. more air needs more fuel, right?
JoeWagon
03-02-2004, 11:39 PM
Please, don't give people such horrible advice.
First, you don't want to disconnect the recirculation hose from your BOV. It has no purpose whatsoever except to make it louder, and can cause problems.
Second, a BOV upgrade is necessary, however, $200 dollars is not. A used 1g BOV will run you 40-50 dollars. If you really want an aftermarket one, have fun paying 200-400 dollars (some of the expensive ones aren't even as good as the 1g). And once you get a new BOV, put that recirc. tube in it's place.
Stock 1g BOV will hold any boost you'll be running until a serious turbo upgrade is installed. Have fun.
RiceRocket18
03-03-2004, 12:50 AM
yeah don't listen to me :owned: these peps have more knowledgable experience. forget what i said. :crying:
i apologize guys. :shakehead
other than that, that's how you make it louder.
TurbosR4me
03-03-2004, 01:28 AM
IMHO dont vent your BOV to the atmosphere. It just causes problems wiht a stock 2g MAS (more than its worth for just the extra loud "PsssssssHHH"). Some kids will run vented for years and not notice any driveability issues, but I personally dont think its worth it.
BoostedSpyder
03-03-2004, 12:27 PM
like i said, since you ALREADY have a 1G BOV, you don't need anything. except a bigger fuel pump ;)
