oil coming out of the side of the engine?
Masta
03-02-2004, 07:01 PM
well..i popped my hood today and i saw oil covering my transmission and covering the engine code. You guys know what my problem is? lol yea i'm leaking oil...but not sure where.
lilol89crx
03-02-2004, 07:20 PM
hmmmmn valve cover gasket, dizzy o-ring, head gasket? simple green it and spray the oil off n see what happens.
POScar49
03-02-2004, 08:54 PM
ur head gasket is blown. dont u pay attention to ur temperature gauge? i bet ur radiator is dry too cuz all the coolant has boiled out alrdy. i hope u have money...
alexdog69
03-02-2004, 10:34 PM
most likely distributor O-ring or valve cover
clean your motor with simple green/spray nine/gunk/pressure washer/whateverfloatsyourboat and then find the source of the leak
do u have any pics ?
91civichatch2571
03-02-2004, 10:54 PM
uh.... what makes you think its the head gasket?
lilol89crx
03-02-2004, 11:19 PM
^^^^ too many variable to firmly state the head gasket is gone.
T-Mo
03-03-2004, 12:17 AM
I say O-Ring on the back of the distributor. I just had this replaced on my Prelude.
habib_88
03-03-2004, 01:11 AM
distrubtor O-ring. I work at a car dealership they have drawers full of random parts. One was o-rings and I found the size for my distrubtor so i got a bunch lol. When you install it put a little grease around it I noticed it seals a wee bit better and they say it will keep it from leaking longer (if it decides to do it again). Also a thing you can check is make sure your 3 bolts holding your distrubtor are snuged down also.
POScar49
03-03-2004, 01:53 AM
im was just making a random assumption that he meant oil was shooting out from the side of his head. stupid me :-P
Masta
03-03-2004, 04:18 AM
lol nah bro, i know a blown head gasket when i see it. I had a blown head gasket on my last 2 engines. Yea, i think it is my distributor. Me and BamBam89LX (jordan) were looking at my distributor one day and he was like "dude, you only have 2 bolts holding your distributor" So i'm guessing that may be my problem. I should just put that bolt back in and it should be fine hopefully. Most likely i bought the engine like that cuz the guy who did my swap just dropped the engine in.
bambam89lx
03-03-2004, 10:03 AM
I'm 100% sure it's not the o-ring. There's actually only ONE bolt holding the dizzy to the head which is the top bolt. I'm almost sure thats the problem. I know its not the gasket because he doesn't blow blue or white smoke and doesn't burn oil/coolant and his car runs clean. Also, the engine is a 99 and has barely 40k on it.
The reason his temp gauge was always up wuz because he had alot of air in the system but he bled it and that problem has been fixed.
Mtrujillo
03-03-2004, 06:46 PM
Just get new seals, thats what I did. I replace the valve cover seal and the dizzy seal and spark plug seals pretty much the whole kit and it all work. No more oil leaks and it's clean as a whistle...
bambam89lx
03-03-2004, 06:56 PM
yah, or just put the bolts in that are missing...lol...that would solve the problem of oil leaking from the dizzy. We put the boltsin today.
lilol89crx
03-04-2004, 07:15 AM
. Yea, i think it is my distributor. Me and BamBam89LX (jordan) were looking at my distributor one day and he was like "dude, you only have 2 bolts holding your distributor" So i'm guessing that may be my problem :P my car only has 2 bolts holding the dizzy now....the rear bolt is a pain for me so ive always left it out. never had a problem and always kept them tight.
