87 brougham steering wheel loose
elmarblach
02-28-2004, 03:35 PM
Hi folks,
the steering wheel on my 87 fleedwood brougham seems 'loose' meaning it moves up/down and left/right about a half an inch.
can I repear this or does this even matter?
thanks
MagicRat
02-29-2004, 04:20 AM
Is the whole column moving or just the wheel?
It may be bad bearings in the column.
The column can be rebuilt, but sometimes with the older columns its easier to find an entire column from a wrecking yard and swap it in.
It might also be a loose bracket inside the column, too. The Jeep Cherokee section had a thread on this, with a quick fix, from about 6 weeks ago. They use the same type of column
elmarblach
03-01-2004, 05:28 AM
I think its only the bearings in the column. I'll check out the Cherokee section.
Thanks much for you help
Elmar
danthemanluvatan
03-16-2004, 08:45 PM
The column probally has 4 bolts that are loose in it. You will have to tear column down a ways to get to bolts. Once there, apply threadlocker to bolts and reinstall bolts.
korn-fed caddy
04-20-2004, 03:16 AM
it is a ring around the steering spindle with bearings this comes from using the telescoping wheel as a hoist
