Service Check Light always on
efsmile
01-03-2002, 09:02 PM
I have just purchased a 1987 BMW 325i that has a Service Check that stays on. Even though it was recently serviced (oil change) the light has suddenly come on and stays on. I am told by a BMW dealer that it would take a new computer board to fix this problem (about $300 for part and labor). I would like to just disengage this light somehow because I already know when to service my vehicles. How do I go about turning this light off for good. I've been told that I will need to warm the car up every few days so that I don't drain the battery. Is the so called replacement board necessary for anything else but to let me know when service is needed? If not then I would rather not put any more money into this. Otherwise, the car runs fine. Any advice you can give would be highly appreciated
bmwe30cr
01-08-2002, 08:38 PM
Have you tried to reset the service lights?
bmwe30cr
01-08-2002, 08:47 PM
If this is the type of injection you have in your bmw here:
http://www.bmwe30.net/pic/tech/sil.gif
Just use a jumper wire between the two red marked terminals, then turn the ignition key to ON, without starting the car!!!. When the lights turn on about 3/4 seconds and then turn the ignition off, if you do this for another 6/7 seconds you will perform and inspection reset.
If this doesn't help you try replacing the bateries on the SI board before making the big investment
