upper IC pipe
RiceRocket18
02-27-2004, 12:52 PM
can you guys tell from this pic if i have the upper IC pipe upgraded?
http://www.digitalinvent.com/files/engine.jpg
EclipseRST
02-27-2004, 01:02 PM
yes you do have a upgraded upper IC pipe... along with what looks like a Greddy Type S BOV...
EclipseRST
02-27-2004, 01:03 PM
looks like you need a new filter!
RiceRocket18
02-27-2004, 01:27 PM
what's wrong with my filter!!?.. i think it's just dirty.
and which part exactly is the upper IC pipe. i know the one below and next to the Type-s is the downpipe
EclipseRST
02-27-2004, 01:31 PM
i dont know if you talking about the one the type s is connected to or not but that is the upper IC pipe! the black tube that has the BOV on it!
EclipseRST
02-27-2004, 01:33 PM
yea your filter is just dirty... i wasnt sure if it is a washable one.. if so just wash it out!
RiceRocket18
02-27-2004, 01:38 PM
i thought that was the downpipe. or are they the same?
yeah. i remember my frieend telling me to take it out and rins it. i just don't know exactly how :screwy: :iceslolan
EclipseRST
02-27-2004, 01:49 PM
down pipe is on the exhaust side of the turbo... goes *down* and back to the cat!
RiceRocket18
02-27-2004, 01:51 PM
so you can't see it from this picture then. is it directly down below the turbo?
EclipseRST
02-27-2004, 02:18 PM
right... it will be right next to the dip stick, just look under the heat shield and you will see it!
RiceRocket18
02-27-2004, 02:35 PM
what happens if the airfilter gets dirty.. will i notice a big performance drop from my turbo boost? i don't know how to clean it up. and how do you know if it's a cleanable one.
EclipseRST
02-27-2004, 02:54 PM
well i dont know if that one is washable or not, the only way i know if they are or not is when ya buy it, if it says washable on the box it is, and if it doesnt the most likely it isnt! :icon16: being dirty can cause some loss in power, so id suggest replaceing it or finding out if it is washable and wash it if it is!
RiceRocket18
02-27-2004, 03:11 PM
how do you wash them. lift up the hood and start spraying?? LOL :lol:
JoeWagon
02-27-2004, 05:01 PM
Jesus..
air filters FLOW AIR, so dirty will flow less air.
A washable air filter you take it out then use filter cleaner.
ashah000
02-27-2004, 05:20 PM
JoeWagon, should you use filter cleaner.
I have the same filter as he does and i just wash it with warm water and then let it dry. It works for me, it gets clean
BoostedSpyder
02-27-2004, 06:14 PM
that looks like an hks foam style, i believe you can wash it with warm water and a LITTLE soap [cuts grease]. i wonder if your dump tube is cut... seeing as you seem new to the 4g63, you should look into it ;) and the UICP's look like Dejon Tools.
ashah000
02-27-2004, 06:52 PM
The filter is the hks super mega flow filter
RiceRocket18
02-27-2004, 07:42 PM
yeah.. turned out that it's the SMF super mega flow filter 200mm NONE WASHABLE!!!.. i just ordered a replacement.. only cost me $14. so no biggie :iceslolan
kjewer1
02-27-2004, 10:57 PM
Just some added info, it appears that you have the HRC UICP, both halves. As far as I Can tell anyway. They're 99 bucks each IIRC. Comes flanged for the type-s too, which makes sense. I ran those pipes with a 1g BOV modded to work on that flange into the low 12s.
RiceRocket18
02-27-2004, 11:51 PM
ok.. you're gonna have to explain what you just said in ENGLISH!.. :screwy: :screwy: it's a little too much to handle for my fragile little NOOB mind. point to the picture if you can :eek7: :iceslolan
kjewer1
02-28-2004, 03:04 PM
The black poweder coated pipes going from the side mount intercooler to the throttle body. The "upper" half goes to the throttle body from just after the BOV. I cant see the lower half, but I know its there because the BOV attaches to that ;) Most aftermarket UICPs stop at the BOV, and you use your stock rubber hose after that. Actually, you can see the lower half, just behind the filter.
