lights
lil_mac
02-26-2004, 09:37 AM
on my 95 integra se i have a check engine light and a maintence required light that tells me when to do oil changes and stuff well i changed the oil myself and dont know how to reset the maintence light.
can anyone help me???
d4f4stnd4fur1uz
02-26-2004, 09:47 AM
i'm pretty sure that in the gauge cluster (where the speedometer and tach are), that there should be a place to put your key into. just put your key in there, and the square should be green now.
That's what i had to do on my civic, not too sure if it's the same for integs.
tsugsr
02-26-2004, 10:28 AM
on my 95 GSR teg, follow the steering coloum all the way down to the base of the plastic right above the brake pedal, there should be a little green square button, turn the car on the hold this in for a few seconds, i just did it the other day.
AlumGsr
03-02-2004, 08:13 AM
Tsugsr Is Right. It Tells You In The Owners Manual, If You Have One, Where To Find It. Make Sure That At High Mileage You Do The Nessesary Maintenance. The Light Is Not Just For Oil Changes, But For Tune-up Reminders And Timing Belt Changes. If Your Timing Belt Goes, Then You're Screwed. Its All There In The Manual.
integRS
03-02-2004, 11:45 PM
on my 98 RS it's blue...not green but you'll know what it is when you see it
