Tire and Gear Ratio
TheRangerOfDanger
02-26-2004, 09:34 AM
Some one was asking about how to tell what size gears one would want when changing tire sizes - here's the formula via Four Wheeler Magazine..
tire diameter=mph x rear end ratio x transmission ratio x 336 / engine rpm
x is multiply
/ is divide
this formula would determine at what rpm you want the engine to be turning at a given vehicle speed
x is multiply
/ is divide
TheRangerOfDanger
02-26-2004, 09:35 AM
depending on the tire size - -this should help you determine desired tire size/gears
2000mudder
03-06-2004, 05:47 PM
you can also use the quick method. if you start off with a 4.10 ratio with a 31 inch tall tire, a 32 inch tire will drop ratio to 4.00, a 33 inch tall tire will be a 3.90 gear ratio, ect.
