91 B250 electrical problems
onthemark
02-24-2004, 05:02 PM
I am having problems with my 91 Dodge B250 Van. Wifey turned off the van everything worked. Got back in later and the power windows , the blower motor, and the back up lights dont work. I checked all fuses but can't find the problem. HELP!!!!!!!!!
slantsixness
05-03-2004, 12:10 PM
ignition switch. try turning it off and on a couple of times, and check the connector at the bottom of the column.
Slantsixness
denmuso
07-04-2004, 01:14 AM
ORANGE....20 GAUGE.......FUSEABLE LINK.......PROBABLY BURNED OUT
BEHIND BRAKE VACUUM BOOSTER.......CHECK BOTH ENDS OF THE LINK
WITH VOLT METER(SHOULD ABOUT THE SAME AS BATT.) ....IGN. ON
LINK IS ABOUT $2.00.......MUST BE SODERED WITH ROSIN CORE
