91 accord a/t trans code 8??
96720
02-24-2004, 03:38 PM
problem with shift solenoid B. which one is shift solonoid B? i'm guessing the bottom pair. what could be the cause of this? this is the only code that it throws. it feels like only 2&4th gears work....and reverse. i already tried replacing both pairs of solonoids with ones off my previous trans, but still same. any ideas? :banghead:
mwkirchner
02-26-2004, 11:34 PM
The solenoids you are speaking of come in a set ... A & B ...
I have enclosed a picture of what you are looking for:
http://www.geocities.com/mwkirchner2000/hondaforum/solenoid.gif
Hope this helps you.
Mark
Mark
96720
02-27-2004, 04:59 PM
thanks! well, i've already tried changing those solenoids....still no luck. maybe trans is blown....doh! i'm gonna check the wiring this weekend...shouldn't be the problem though, i didn't touch anything with the wiring. oh well...auto trannys suck.
96720
03-01-2004, 09:27 PM
can anyone tell me if these atf oil lines are hooked up correctly?
http://we-todd-did-racing.com/wetoddimage2.wtdr/i=wMjk2NTc0NnM0MTNkZmQzMXk1NDE%3D
96720
03-03-2004, 06:02 PM
bizump
My90AccordEx
03-08-2004, 03:52 AM
Where did you get the code description and how did you get it?
When I short circuit the connector under passenger dash board to find out my tranny problem, my 'S' light flash.. one long flash and 2 short flash, I belive that means multiple error which are code 1 and 2 (I assumed), but I couldn;t find the code for transmission.
If you know what code 1&2 is, let me know.
Will appreciate that. Thanks~
