Blinkers
sthrnbel
02-21-2004, 09:05 AM
97 Mitsubishi Spyder GS: My blinkers don't work but my hazard lights do. All the other functions controlled by the column switch work but the blinkers. When I use the turn signal, nothing happens: No lights, no clicking sound, nothing. The headlights are fine, including brights, so the only thing apparently affected are the blinkers. The fuse is fine. I'm changing the flasher relay today to see if that is the problem. However, I am having a hard time locating the flasher. Sounds like it's behind the A/C controls. Thanks
xjoeharperx
02-21-2004, 10:43 AM
if the flasher relay doesnt fix it you will need to tale the switch out and see if you have power to the contacts, and power coming out of the switch.
sthrnbel
02-24-2004, 07:58 AM
Ok, tested the switch and there is no power coming out of the switch but coming in. I ordered a new switch so we'll see how that goes...in the mean time, I will have to show off my left arm a lot =)
