'89 2.2L head swap
HackerX
02-19-2004, 09:54 AM
is their a DOHC head that can be fit directly onto a 2.2L block on a '89 probe. I recently received this car from a relative for free, the timing belt was snapped and the head's valve train is messed up. I'm also planning on turbo charging it, straight-flow exhaust(w/ turbo) or cat-back(N/A), new fuel management system, and distributorless ignition system.
This car also has the stock 5 speed manual.
Playa88_01
02-20-2004, 08:49 AM
That I know of there is no DOHC head that will fit. Also, if you turbocharge that engine the tranny you have will not work the right way. The flywheel and clutch are both smaller on a non-turbo tranny.
