motor swap
dwrock1
02-18-2004, 04:58 PM
so when i finaly get a 97 gsx do i need to swap the motor to a 1g to keep from getting CrAnKwAlK?
dwrock1
02-18-2004, 05:34 PM
do only 5 speeds get crankwalk
JoeWagon
02-18-2004, 06:35 PM
No, you only need to swap the motor IF you get crankwalk, and not only 5 speeds get them if i'm not mistaken.
ashah000
02-18-2004, 07:06 PM
If auto's can get it, I think that the chances are very low. I have not heard of an auto with crankwalk. But I could be wrong.
gthompson97
02-18-2004, 09:49 PM
i have an eagle talon tsi awd with and automatic and it crankwalked on me (they have the exact same engine as the eclipse turbo if you didn't know) but i also have a few bigger mods to it like a t3/t04 turbo, injectors, and that stuff so that could have contributed to the problem.....none the less it still happened.
dwrock1
02-19-2004, 12:02 AM
i was saying y not go ahead and get a 1g motor as soon as i get a 97 gsx to avoid CW all together
JoeWagon
02-19-2004, 01:40 AM
Because it's a waste of money. Why would you buy a car then get rid of it's working motor? FIRST you get crankwalk (if you do) THEN you replace
stop worrying about it, you most likely won't get it.
EclipseRST
02-19-2004, 07:08 AM
i second that! you should spend a good amount of time searching about CW cause obviously you dont know much about it! and after doing research on it you will see why everyone will tell you to keep the 97 motor unless it CWs on you or you blow it up somehow! thats the only reason i am putting a 6 bolt motor in my car, because my engine was was messed up! it didnt have CW just 2 spun rod bearings and it was cheaper for me to buy a 91 6 bolt motor then to by new rods and a crank! so go look up CW and if you still feel like you have to change the motor then i guess you are wasting your own money so i dont care, but whatever you do... good luck!
gthompson97
02-19-2004, 08:10 AM
get rid of the 2g engine while it's still running so you can get some $$$ out of it before it cw's or blows so you just have to trash it and drop in a 1g. saves you time and money in the longrun.
FourG63 97GST
02-19-2004, 10:06 AM
care to explain how the hell does that save you time and MONEY :rolleyes:
dwrock1
02-19-2004, 11:29 AM
exactly what i was thinking
dwrock1
02-19-2004, 01:50 PM
im just asking alot of question b/c i am new to the eclipse world and just found out about CW bout 2-3days ago
JoeWagon
02-19-2004, 01:58 PM
Lots of people who just find out about crankwalk get their panties in a twist.
You won't save money by ditching a good engine. The chances you get CW are so low, and depending on how many miles you have.. your chances could be near 0. I could go on, but there's nothing more to say. Crankwalk is like a car accident. You don't prepare for it by selling your car, because not everyone has to worry about beign in one.
dwrock1
02-19-2004, 02:05 PM
ok thank you
FourG63 97GST
02-19-2004, 05:19 PM
Well said!
