limited slip
carpunk
02-14-2004, 12:56 PM
does a 97 ls integra have a limited slip differential
tsugsr
02-14-2004, 01:06 PM
Nope, not from the factory anyways.
PunkAlex
02-14-2004, 02:03 PM
what factory differentials fit the ls trans? any at all?
whtteg
02-14-2004, 03:27 PM
It would be cheaper to buy a quaife. I think as long as you haev the S80 you can change out the diff, final drive and I think the counter shaft and it will work, not real sure on that but I think I have heard that. But IMO I would just get a quaife or buy the whole ITR tranny. :2cents:
wickedplastikman
02-15-2004, 03:09 AM
IMO i didnt like the type r tranny. i drove an itr and i was cruising at 80mph on the highway with the rpms around 4 grand. i think the gears are smaller on the type r than on other tegs...i think. but how much does a quaife cost, without install?
whtteg
02-15-2004, 07:34 PM
I have seen them as low as $700 and as high as $900.
PunkAlex
02-15-2004, 09:59 PM
Whats involved in the install? Like is it something i could do with my car on jackstands in the driveway?
tsugsr
02-16-2004, 10:03 AM
man all tegs are gonna be realitvly high in RPMs at highway speed, my GSR is at about 3800 in 5th at 80mph, alot better than my old pos ls, 4 grand at 70 in 5th.
Plastic_Fork
02-16-2004, 10:59 AM
I would keep the LS transmission and install an aftermarket LSD. The LS gears are pretty tall - taller than the GSR and Type-R gear ratios I believe. All you need is the power to back it up and use the full gear length.
I think the B-series VTEC motor gear ratios are all shorter than non-VTEC. I might be wrong. My B16A gear ratios are pretty short though. 80mph on the highway usually puts me at about 5,000rpms in 5th gear.
