Lightwieght flywheel and pulley?
IntegraB18LS
02-14-2004, 12:42 PM
I have a turbocharged B18B1, I am ordering the ACT 12.5lb flywheel this weekend, I was told the 8.8 lb would be to hard to drive, I have a JDM CTR N1 crank pully sitting here that I been meaning to install, should I bother installing it now or will I loose to much of rotating mass and not be able to go anywhere, and might as well get the 8.8lb?
whtteg
02-14-2004, 04:12 PM
The crank pulley, is it OEM or afertmarket? If it is aftermarket you need to make sure it has a harmonic balancer/damper on it, or you will be having problems down the road. Some people don't agree with me but most of the more experienced tuners do agree.
IntegraB18LS
02-14-2004, 04:36 PM
Yes it is a OEM JDM crank pulley 1 lb 13 oz
whtteg
02-14-2004, 04:45 PM
You should be fine but do note that you will fall out of the revs alot faster than before so you are going to need to shift as fast as you can. And good choice with the 12.5 the 8.8 would be a little too light for daily driving.
