Start up problem
da~bomb
02-12-2004, 05:49 PM
89 2.8 Automatic
VATS (resistor in key)
Changed: starter, pos battery cable
Problem: After driving a while, the car will not restart until it cools down. This problem is driving me crazy! Please help!
Thanks ALL
rccat
02-12-2004, 08:42 PM
On my toyota 4 runner I had the same prodlem
I think it is in the wire harness at the ignition swicth
not the ignition swicth. but were the wires make conact in the plastic houseing.
I did put new wires (but not the houseing) this helped
but it didn't solved the problem it's in the metal contacts.
I replaced
The starter
The cables 2ea.
The battery
The ignition swicth
The wireing
The only thing left is the plastic mount for the metal
contacts behind the ignition swicth.
This only what I think.
rccat
02-12-2004, 08:45 PM
Ohh how I got by was jump starting the starter motor,
with a piece of wire.
Then it started evey time bypassing the contacts and wireing
tomminajar
02-14-2004, 12:34 PM
Check to see if your fuseable links are good 2 are right on by the starter-check for continuity on each side of them w/battery disconected-
bet that is it...
Sounds like solinoid wire is bad Check for + 12v in key on 'run'
Can you hear the solinoid click when it won't start ??
da~bomb
02-14-2004, 02:58 PM
No sound from starter...
But all other is good (lights,radio,dash...)
'91 GTA
02-17-2004, 10:13 AM
I have the same problem in my '91 GTA, doesn't happen all the time...just enough to be annoying. There is no sound when you turn the key, but there is power. I replaced the solinoid but it still does it from time to time.
87_TA_GTA
04-14-2004, 06:21 PM
Also note if you have the tilt wheel option and your car has trouble starting, make sure the tilt wheel isn't all the way up. Try lowering it and see if it will start. That is what happend to my friends 85 firebird, he found that out after replacing the solenoid.
