Exaust Prob.
SouthernThunder
02-11-2004, 07:11 AM
I've got a 84 FirebirdTA it's had exstinsive mods done to it and the only the prob i ran into was no clearance for the exaust. I was thinking about sidepipes without the 180 degree J bend with a one chamber flowmaster right before it exits the underside of the car. My question is this will I get good performance out of that? Or if anyone has a suggestion on another system thx. :banghead:
rccat
02-12-2004, 09:03 PM
Not sure but go with a larger pipe.
Say 2 1/4 at the manufold ( or what ever you have)
Then 3" after that to make up for the bend?
SouthernThunder
02-13-2004, 07:06 AM
thx for the sugesstion that sounds like a good idea
petereggy
02-15-2004, 01:25 AM
no clearence for the exhaust? if it dosent have the dual lines set up in the floor boards try running a single 3 or a 3.5 inch pipe following the stock route
double check flowmaster.com they have a ci/hp diagram for pipe size
SouthernThunder
02-15-2004, 06:47 AM
I was trying to stay away from the single exuast if I could, I would like to run the sidepipes I'm just not sure if they may be to loud, they come with glasspacks and to be honost I just don't like glasspacks and the one chamber Flowmaster is the only thing I know of that dosn't give a bunch of back pressure, I need some but as much as a single exaust sytem will provide
ErickJ
02-18-2004, 07:02 PM
Well, I'm not certain on this, but I've heard of really good muffler shops being able to convert single exhaust to dual-exhaust with little problems...
I'd just talk to a well-known muffler/welding shop who knows their stuff and ask them if they can create a dual set-up that will give good performance AND give you ground clearance...
Erick J.
[email protected]
