Creaky Sqeaky Door Panels...Ugh!!!!
mustangnutbcuz
02-10-2004, 08:18 PM
Hey everyone. I'm just writing to let you all know that I have fallen in love with this website. You mustang people are the most informative bunch of car nuts out there. Thanks for all the help. Now, on to the problem...my mustang is going on five years old and i'm starting to notice that the door panels are starting to creak and squeak when i touch or lean on them, or when i go over bumps. Its driving me nuts cause it makes my car sound like a piece of crap. I was wondering if anyone else has experienced this and if they knew of a way to try and tame the horrible noises. Again, thanks for all the help. :smokin:
stang_racer20
02-10-2004, 09:25 PM
well you didnt say what year it was but i guess there all pretty much the same. I would first replace all the push pins, which should help to tighten up the door panel. If that doesnt help try putting like a real thin layer if of foam padding(stickable) on sections of the door. You also might try using some white lithium grease on any bolts in the door panel and tighten em up good.
SIKCRX
02-10-2004, 11:19 PM
atleast yours is all in one piece :P
HiFlow5 0
02-10-2004, 11:47 PM
Also check the striker latch on the door frame below the B pillar. A lot of times the plastic bushing around it breaks off and allows the door to jiggle around a bit. Replacement strikers are pretty cheap if that's the case.
mustangnutbcuz
02-11-2004, 07:04 AM
I really appreciate the help. I forgot to mention its a 99. I'm going to replace the push pins as well as put on a thin layer of foam. Anyone have any idea where I might be able to find such a thing. Thanks again.
StangNut86
02-11-2004, 11:32 AM
www.50resto.com
should have everything you need, except maybe the foam. as for that, you get that at a little scrap store or something if you're not too picky
www.50resto.com
okie-chevy-man
02-11-2004, 12:18 PM
Mustang nut and stang racer.. you 2 guys just cracked me up. stang racer he said it was going on 5 years old and you said he didnt say what year it was. then Mustang nut is like i forgot to mention... your confidence level is so low. you should have said "i told you how old it is DO THE MATH!!" thats some funny stuff.
mustangnutbcuz
02-11-2004, 02:43 PM
Its not the my confidence isn't high, I just don't want to be a dick. Besides, math isn't my specialty. Either way, I appreciate the help, I'm going down to a rag shop near my house, they said they have the foam. I'll let you know how I make out... :smokin:
stang_racer20
02-11-2004, 09:24 PM
Well I guess I just get so excited to help people I get ahead of myself. I'm sorry I didnt measure up to your standards okie chevy! :sly:
