2000 C/K 4X4 service light and malfunction
slacker_53
02-07-2004, 12:37 AM
Hi all,
I have a 2000 Z71. Today I used the 4X4, no problem, later on I tried to use it again and it went into 4X4, when I shifted out, I noticed the LEDs on the switches weren't lit and it seemed to stop working.
It became apparent that the truck was in 2 wheel drive and wouldn't shift to 4X. After driving about 10-15 miles the 'service 4X4' light came on.
I've checked the fuse, is there anything else I can check before taking it to the dealer for diagnostics?
Is there another fuse that isn't shown in the owner's manual? I only one I could find was the one 15 amp in the dash fuse block and it is okay.
I didn't see any listed in the fuse center under the hood. Any help would be appreciated.
This is the electronic 4X4 with the Automatic 4X4 button and neutral position.
Thanks in advance
-slacker
GMMerlin
02-07-2004, 08:41 AM
Service 4WD Indicator Illuminated, DTC B2725 Set (Replace Transfer Case Shift Control Switch) #02-04-21-004 - (04/15/2002)
"Service 4WD" Indicator Illuminated, DTC B2725 Set (Replace Transfer Case Shift Control Switch)
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Silverado, Sierra, Avalanche, Suburban, Tahoe, Yukon, Yukon XL)
with Four Wheel Drive and NVG 236/246 Transfer Case (RPO NP8)
Condition
Some customers may comment on the Service 4WD indicator illuminating. Upon investigation, the technician may find DTC B2725 set.
Cause
The condition may be due to a intermittent fault in the transfer case shift control switch.
Correction
Replace the transfer case shift control switch using published Service Information procedures.
You can also contact Galvin Curtis of circiut solutions..he cruises these boards a good bit,,he has been repairing these switches.
slacker_53
02-07-2004, 08:47 AM
Like I said, the lights in the dash switch itself are not illuminated, Is the activation switch you are pertaining to, the dash switch?
slacker_53
02-07-2004, 08:50 AM
Where do I find the DTC 2725 or what is it??
